Vibration dampening motor gasket?
sam.m5
(@sam-m5)
Hi everyone,
My MK2 is noisier than I'd like, and a lot of that seems to come from motor vibrations (rather than the rods). I was wondering if anyone had had success using dampening gaskets such as these:
https://www.aliexpress.com/item/Funssor-1pcs-NEMA-17-Stepper-Motor-Anti-Vibration-PTFE-damper-Vibration-Damper-Shock-Absorber-for-CNC/32815722890.html
- Do they make much of a difference?
- Is PTFE a good material for this purpose?
- Any gotchas in installing them? I can imagine I'll get to get some longer screws, but apart from that is there anything i should be aware of?
Thanks,
Sam
Publié : 13/11/2017 12:28 am
AJS
 AJS
(@ajs)
Re: Vibration dampening motor gasket?
I suggest using the forum search function.
https://shop.prusa3d.com/forum/improvements-f14/stepper-motor-damper-benchy-don-t-lie-t5771.html
Publié : 13/11/2017 3:17 am
