USB extension cable
RobM
 RobM
(@robm)
USB extension cable
Hello Everyone, I need to extend my USB cable by just 1 metre and have tried two extension cables that I have but I cannot connect when using either - am I missing something simple here?
Appreciate the help...
Cheers, Rob
Napsal : 19/09/2017 12:19 am
henrik.w
(@henrik-w)
Re: USB extension cable
Hello Robert!
I am too using an extension usb cable that is 5 metres long and have no issues. Total length is 5m + the original cable length. So I don't think it could be voltage drop in your case.
Could it be two bad cables in your case - or one bad original cable?
/Henrik
Napsal : 19/09/2017 10:00 am
Vertigo
(@vertigo)
USB cables can be finicky. Another printer I had, would only work with 1 out of 5 (normal length) cables. Those cables worked fine with other devices. Why? I have no idea. Do yourself a favor: get a raspberry Pi with wifi, install octopi, and put your printer anywhere you want.
Napsal : 19/09/2017 10:10 am
RobM
 RobM
(@robm)
I found yet another USB extension in a drawer, just 50cm, but it worked and is just long enough...Like you say luck of the draw(er) 🙂
However, I do like your idea about the Raspberry Pi, to get info over by wifi and, after checking YouTube, I think a camera too for time lapse. So, thanks for your reply.
Napsal : 22/09/2017 7:34 pm
RobM
 RobM
(@robm)
Hello Robert!
/Henrik
Thanks for your reply. I did find another and it worked...
Napsal : 22/09/2017 7:35 pm
