Uneven layers and bad top layer
Theodor Sjöstedt
(@theodor-sjostedt)
My MK2s recently started displaying these uneven layers, and also the top layer looks pretty bad.
Printer
  • The printer was delivered in June as a kit
  • It gives the "your printer is square, congratulations" message on calibration.
  • 3.0.12 firmware
  • Noctua fan and shrouding
  • E3D hot end silicone thing
  • I have performed a PID tuning.
  • Material
    The material in the image was light grey PLA from PrimaSelect, but its the same phenomenon in other material from other manufaturers, and I've printed successfully in this material before.
    Slicing
    Stock standard Prusa Slic3r 1.35.5 0.20 mm NORMAL setting. (except for added PID values to pre print gcode)
    The live z height is set using this method http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/life-adjust-z-my-way-t2981.html
    Publié : 14/08/2017 10:10 pm
    GertL
    (@gertl)
    Re: Uneven layers and bad top layer
    Hi Theodor
    It looks a bit "wet", maybe you have a bit of over extrusion?
    Take look at this page, made wonders for me.
    https://mattshub.com/2017/04/19/extruder-calibration/
    Gert
    Publié : 15/08/2017 9:02 am
    Theodor Sjöstedt
    (@theodor-sjostedt)
    Tried this out, and I could not see any real over extrusion happening :/
    Actually what I think I have problem with is a partially clogged or broken nozzle. I'm waiting for a replacement and will try that one out.
    Thank you
    Publié : 17/08/2017 5:20 pm
    GertL
    (@gertl)
    Maybe you can lower your extrusion multiplier in the slicer.
    For some filaments i have 0.95 and some 1.05.
    Gert
    Publié : 17/08/2017 6:42 pm
    grzegorz.k3
    (@grzegorz-k3)
    I have exactly the same problem with Devil Design 1,75 mm PLA Startpack 6*0,33kg. Did nozzle replacement help?
    Thanks,
    GK
    Thank you
    Publié : 31/01/2018 6:06 pm
    Nikolai
    (@nikolai)
    Second over extrusion. As already suggested try to lower the multiplier in 2 or 3 percent steps and check the results.
    Other options to try is:
    -> lower the print speed
    -> lower the temperature
    Often linked posts:
    Going small with MMU2
    Real Multi Material
    My prints on Instagram
    Publié : 02/02/2018 7:08 pm
