Trying to print 5-link chain - stringing and knockover problem
Ira S
(@ira-s)
I just built and calibrated my MK2S printer. All of that went smoothly. Also printed the PRUSA test and that worked just fine.
I'm now trying to print a 5-link chain as a test. I've found this to be a good test of printers.
I'm having two problems. First, there seems to be a lot of stringing as the printhead moves between sections of the chain. I can deal with that, but I don't have that problem on my old i3 printer.
The more important problem is that as the print progresses, the printhead strikes and knocks out one or more sections.
I have adjusted the first layer using Live-Z adjustment so that the first layer is firmly attached (at least reasonably, I'm not trying to get a completely squashed first layer).
I'm using the standard settings from Slic3r Prusa Edition for PLA when slicing.
Attached are 2 pictures to show my problem.
Any ideas?
Postato : 16/10/2017 11:49 pm
AJS
 AJS
(@ajs)
Re: Trying to print 5-link chain - stringing and knockover problem
You need to squash that first layer more. Please read this post
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
especially step 6. Getting that first layer is critical. From your photo, I can see you don't have your Live Z down low enough.
If you need help, printing the calibration square from step 6, and post a photo, and we can help.
Postato : 18/10/2017 3:05 am
