Trouble with PLA adherence
ryan.f15
(@ryan-f15)
This is my latest print. I tried printing with raft but where the part joins the raft it broke lose. Now the part is ruined. What should i do to fix this?
Opublikowany : 05/11/2017 6:10 am
Sidbitters
(@sidbitters)
Re: Trouble with PLA adherence
How are your test squares turning out from the live z adjustment? They should be smooth and when you hold them up to the light, there should be no holes. Is your bed cleaned with high % ipa? I am a real begginer but my pla gets really stuck on the bed.
Opublikowany : 05/11/2017 4:10 pm
ryan.f15
(@ryan-f15)
I clean with 50% alcohol after almost every print.
Opublikowany : 05/11/2017 5:35 pm
GertL
(@gertl)
Try to get some 99% IPA or Aceton to clean with.
Also, make sure that your Live Z is squeezed down properly as Ray says. https://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/life-adjust-z-my-way-t2981.html#p45296
Gert
Opublikowany : 05/11/2017 5:44 pm
AJS
 AJS
(@ajs)
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
Opublikowany : 05/11/2017 6:03 pm
ryan.f15
(@ryan-f15)
I keep trying to print that and it will print twice, then give me a Z adjustment error.
Opublikowany : 05/11/2017 7:13 pm
surfgeorge
(@surfgeorge)
What is your print orientation on the bed?
Best would be to post a screen shot of the slic3r 3D preview
Opublikowany : 05/11/2017 11:24 pm
