Terrible Prints
courtney.k
(@courtney-k)
Terrible Prints
Okay,
My printer was printing beautifully until one day it just out off nowhere started printing garbage. I've tried everything. Taking apart my extruder, treating for a nozzle clog, recalibration, adjusting the PINDA probe. I don't think its under extrusion either because when I run the extruder, filament comes out perfectly. But judging by this picture, do I appear to have a bed adhesion problem? It's really the only thing I think it could be at this point besides something internally wrong. HELP!!
Opublikowany : 03/02/2018 5:26 am
JeffJordan
(@jeffjordan)
Member Moderator
Re: Terrible Prints
checked this thread, with all its advices (e.g. for cleaning the bed) ?
by the way: had a similar problem once. needed to replace the nozzle because there was a burned-in remainder of abs inside the nozzles channel, that reduced the extrusion capability. couldn't get it out with the common methods, so the last solution was to replace the whole nozzle (make sure to keep the system "watertight").
Opublikowany : 03/02/2018 8:54 am
AJS
 AJS
(@ajs)
Re: Terrible Prints
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
might help you also.
Opublikowany : 04/02/2018 3:53 am
