simplify3d bed and extruder temp
pbnj
 pbnj
(@pbnj)
Any one know if there is a setting or script that I can change or add to get the bed and extruder to heat at the same time when first starting a print?
Veröffentlicht : 06/02/2017 5:46 pm
Re: simplify3d bed and extruder temp
I choose preheat. Then print from sd card. I think S3d has a wait for temperature to stabilise option in the temprrature menu but i have neber played with it.
Regards joan
Veröffentlicht : 06/02/2017 7:40 pm
jediknight0
(@jediknight0)
Simplify3D will normally heat the bed first then the nozzle (or the other way around... I forget).
To override that behavior, use a custom start script that uses the temperature variables. If it sees the variables in use, then the default behavior is overridden.
My startup script:
M115 U3.0.9 ; use the latest firmware version
M104 S150 ; set extruder temp to 150C, cold enough to avoid ooze but get some temp on it
M109 S150 ; wait for extruder temp
G0 Z60 ; get head above bed to keep it cool
M140 S[bed0_temperature] ; set bed temp
M190 S[bed0_temperature] ; wait for bed temp
M104 S[extruder0_temperature] ; set extruder temp
M109 S[extruder0_temperature] ; wait for extruder temp
G28 W ; home all without mesh bed leveing
G80 ; mesh bed leveling
G1 Y-3.0 F1000.0 ; go outside print area
G92 E0 ; reset extrusion distance
Veröffentlicht : 08/02/2017 8:14 am
danbst
(@danbst)
Nice script.
A 😀
Veröffentlicht : 08/02/2017 10:36 am
