Search something
tetranet
(@tetranet)
Search something
Hello,
Is someone already see this for the Heatbed of the Prusa MK2 :
http://www.thingiverse.com/thing:1335208
My heatbed move a little with some print. I need to stuck.
I hope you understand what i say 🙂 French nOOb is here 🙂
Marc
Publié : 08/07/2016 8:14 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Search something
Marc
The problem with that is that the bed height would change. With the Mk2 it's not a big issue other than reducing the maximum height of the print and if you are careful, then not a problem, but ideally the firmware should be amended to reflect the reduced height (Z_MAX).
With the bearings seated properly and tight cable ties, there should not be an issue though.
Peter
Publié : 08/07/2016 9:38 am
