Save "Z compensation" value
manuel.m
(@manuel-m)
Hi everyone,
I received my assemled i3 mk2 less than 1 week ago. After firmware flashing (1_75mm_MK2-RAMBo13a-E3Dv6full.hex) the printer display was in
Czech Republic language, I am italian and I am in italy! So I googled and make a "soft" reset (that only for language). I did a print with slicer and "optimal" configuration and there was already something suspected about 1st layer height (too height)...but after all she did the print and was pretty fine. After that I tried to do other print but this time 1st layer didn't stick. So after a day of issue and googling I set the 4 corners bed compensation (-0.4) and Z conpensation (-0.5...-0.6...I don't rememer)!
The good thing is I understud that Z compensation help to achive a "perfect" nozzle distance from bed.
The bad thing, and this is why I am writing here for help, is that Z compensation value comes lost after every homing procedure!!
This is what I do:
1- Switch on printer;
2 - variuos calibration stuff...;
3 - printer says it is all ok...no error;
4 - display says Z 0.15 but if I move Z and go to zero I see there is much more than Zero!!!! I think about 0.8 between nozzle and bed;
5 - I go down with Z compensation till I almost touch the bed surface;
6 - Load gcode from sd;
7 - start printing but there is to much distance from bed!
8 (the only way I found for fix this problem) - is the live adjust during printing!! This has no sense becouse when I do the Z live adjut during 1st layer printing, the display show me already the value I set before (point "5")!
CONCLUDING:
I would say that Z compensation value remain not saved! Is this just my problem? I did or I do something wrong?
Slicer offset doesn't work if I write negative value! Is this just my problem?
The firmware does not allow the printer to go under 0.15...sorry but I think this is a stupid choise!
I don't know what to do:
- adjust the probe manually, I mean unscrew and lift it up a bit?
- modify the firmware code and reduce probe offset? I am not expert in this, I downloaded the source code (tar.gz) here https://github.com/prusa3d/Prusa-Firmware/releases/tag/v3.0.10 and still not open it in arduino software. Is possible modify the offset probe with this file? If yes how I load the modified firmware from arduino software into prusa i3 mk2?
- I maybe have to do a fabric reset?
- I maybe wrong the firmware I selected "1_75mm_MK2-RAMBo13a-E3Dv6full.hex" ?
Please help me, thanks!
Manuel
Respondido : 06/03/2017 10:00 am
adrian.s2
(@adrian-s2)
Re: Save "Z compensation" value
Goto this link and carry out the procedure from 14.17 minutes in.
This will help you re-set the Z axis adjustment.
Thanks.
Respondido : 06/03/2017 8:51 pm
manuel.m
(@manuel-m)
Hi Adrian,
now it's ok, thanks! I did it one time but did not undertud that V2 calibration contains command for Z compensation storage that will be deleted every xyz calibration! :geek:
Jeff has explained me yesterday here http://shop.prusa3d.com/forum/original-prusa-i3-mk2-f23/calibration-print-looks-great-first-print-struggle-t3551.html
So I did different xyz calibration without V2...that's the reason why! I belived V2 was just a simply gcode for printing check!
Btw now is solved
Thanks
Manuel
Respondido : 07/03/2017 1:37 pm
adrian.s2
(@adrian-s2)
Thanks for the update Manuel.
I always wondered how the V2 Calibration made the Z-adjust value stick. Now i know it's in the GCode!
Best Regards and happy printing. 😀
Respondido : 08/03/2017 11:16 am
