"Rough" surface on edge of flat print
Hi!
I'm currently trying to print a case for some hex drivers I have, but am running into issues:
The "rough" edge pictures here is supposed to be flat. It happens only on this side, the other side prints how it is supposed to.
I am currently printing with PLA with the bed set to 65 and 210 first layer / 195 all others, I have the fan set to 'off' for the first 3 layers and then on for all others.
Here are my Slic3r Prusa Edition settings (for some reason it wouldn't let me upload more images):
 https://imgur.com/a/BX0wt
I've also had some bad bed adhesion issues, currently the print that I am referencing for this I had to use hairspray on the bed to get it to stick, could these issues be related? I had originally thought this was related to poor bed adhesion, but it sticks with hairspray and the issue has persisted.
From another failed print:
What I've tried:
Let me know if you need any more information.
Any help is appreciated!
Thanks
Re: "Rough" surface on edge of flat print
I would print something from the SD card to determine if it is your printer hardware, or your slicer software.
Hi Jeffrey
It seems the over-extrusion occurs only some mm over the bed... 🙄
It's exactly my case also... Did you fixed this issue ?
Your Slicr parameters are more or less the same.
Vincent from Elsass
Vincent from Elsass 😀
Hi Vincent,
your prints really look horrible.
what are your slic3r settings ? especially fill density and infill overlap ? number of outer perimeters (vertical shells) ?
did you calibrate your extruder (search for the 10cm trick) ?
are all the pulleys and bells "tight" (ohne Spiel) ?
does your filament run smooth from your spool ?
furthermore: how does the print of *.gcodes look like that came with the printer (for example the prusa whistle) ?
Hi
Fill density is very low (10%) and vertical shels is set to 3.
What is the infill overlap ?
Yes, extruder has been calibrated (85 mm consumption for 100mm asking) but I have the same result with extrusion multiplier = 1 (under extrusion)
I will check the pulleys ...
but my belts are very tigh. I didn't found the way to find out the right strain !
Thank for your help and ... Happy new year !
.... By the way, infill overlap is 25% !
