Replacing nozzle - Why is size 17 spanner needed instead of adjustable?
prusayo
(@prusayo)
The manual explaining how to change nozzle indicates that a size 17 spanner should be used to hold the heat block. I have an adjustable spanner, is that ok to use instead of a fixed 17 size?
I got the replacement nozzles in the mail. I can't believe how tiny they are! I don't know why I was expecting something bigger.
Publié : 04/10/2016 3:15 am
David T.
(@david-t)
Re: Replacing nozzle - Why is size 17 spanner needed instead of adjustable?
Adjustable tools should be OK.
Keep eye on heating element, thermistor and their wires. Don't get them damaged.
Publié : 04/10/2016 9:08 am
You should have two 17 mm spanners from the build kit, if you got a kit. 🙂
Regards Joan
Publié : 04/10/2016 9:22 am
prusayo
(@prusayo)
Regards Joan
Ah very good I got that part down now.
However, I bought a 7mm spanner and don't have the strength to unscrew the nozzle. I heated it to 220 and turn counter clockwise but it seems I'm stripping the nozzle instead. What am I doing wrong?
http://e3d-online.com/E3D-v6/Extra-Nozzles/E3D-7mm-Nozzle-Spanner
Publié : 04/10/2016 4:53 pm
David T.
(@david-t)
You need more heat. Heat it up to 300. Tools take a lot of heat off, so you need to provide more heat and work fast.
Publié : 04/10/2016 5:21 pm
prusayo
(@prusayo)
The settings don't allow it to go to 300. I went up to 285 and it still won't come off. The picture in the doc looks like needle nose pliers so I thought it would be easy. Now I stripped it so i can't even use the 7mm spanner I got from e3d nor pliers. I guess I need to buy a better 7mm spanner. I think I am the only one who can't even remove a nozzle.
Publié : 04/10/2016 6:12 pm
christophe.p
(@christophe-p)
Membre Moderator
Using gloves is a good idea too, if you are as clumsy as me 🙂
For nozzle untighenting, I really prefer this kind of socket wrench
I'm like Jon Snow, I know nothing.
Publié : 04/10/2016 6:19 pm
paul.h
(@paul-h)
In the past I have found that a socket set was the easiest way to remove the nozzle (in association with heat of course) - any concerns with that approach?
Publié : 04/10/2016 6:22 pm
prusayo
(@prusayo)
Ok, socket wrench makes the most sense it would seem. I imagine for tightening I should use the regular spanner so as not to over-tighten. Good point about gloves, I better wear those with my luck. Thanks.
Publié : 04/10/2016 6:42 pm
prusayo
(@prusayo)
I got the socket wrench and managed to twist the nozzle right off. Unfortunately the upper part of the nozzle remains in the hotend. Does this mean I need to order this:
http://e3d-online.com/E3D-v6/Full-Kit/V6-hotend-Fully-Assembled-1.75mm-and-3mm
12v / Direct / 1.75mm
Or is there something else I should get or do?
Publié : 05/10/2016 2:49 am
ayourk
(@ayourk)
You can probably get by to just order the Block and Sock kit.
Dimensions PNG
and an 8 inch (200mm) or greater caliper is recommended.
Publié : 05/10/2016 7:33 am
prusayo
(@prusayo)
I ended up ordering the full kit so I have less to mess up on for now, although with my ability I'm getting nervous how to replace it.
Publié : 06/10/2016 4:49 am
mechtheist
(@mechtheist)
Have you tried one of these?
900 ft-lb's ought to do it 😀
Don't worry, I may have manged to get my nozzle off fairly easily, while building it I nearly chucked the printer out the window when I could not for the life of me get the damn air-duct thing to go on. If the bolt would thread, it went on crooked, if it was properly positioned, I couldn't get the bolt to thread. Maddening!
Publié : 06/10/2016 9:03 pm
