Removing Prints with Large Surface Area
Matt
 Matt
(@matt-29)
I printed a model (in PLA) with a large base (large surface area). According to Prusa's instructions, I should use a putty knife or floss to remove the object. Well neither of those worked. So I attempted to heat up the print bed to ~100 deg C, and with a combination of wiggling the model and using the putty knife, the model final came off the print bed.
But now I have a problem. My print bed has never performed the same again. I believe I may have damaged it during removal, somehow, because some areas of the bed are hotter than others when preheated, and I believe the print bed is now warped (after several V2 Calibrations that show bed inconsistencies).
I have 2 questions:
1. How can you remove large surface area prints EASILY without damaging - or risking damage to - the print bed? (Can you use Krypton tape / painter's tape on top of the PEI?)
2. Where can I buy an authentic/genuine print bed replacement for my MK2 (preferable with PEI installed)?
THANKS!
Postato : 05/06/2017 4:25 pm
JeffJordan
(@jeffjordan)
Utenti Moderator
Re: Removing Prints with Large Surface Area
I have 2 questions:
THANKS!
first let's leave "krypton" inside the group of noble gases at the periodic table, you probably mean kapton tape.
then: you can buy a new printbed directly from prusa. but first you have to chat with them, so that they grant you access to the prusa spare-parts section at the shop.
before you have a look at the price and want to order a replacement, i recommend to sit down first.
messing around with a stuck print and a heated up printbed at 100°C will certainly be no good idea and could easily damage the bed.
for the future, have a look at this thread, it recommends a good way for prints with pla.
furthermore adding "mouse-ears" to the printed object will give you the chance to get under the print with a very thin spatula or thin cutter knife.
Postato : 05/06/2017 4:53 pm
