Recalibrate with every new roll?
ryan.f15
(@ryan-f15)
I've found myself having print problems when i change out my filament. Do I have to recalibrate if i go from one pla to another?
Opublikowany : 04/11/2017 10:06 pm
Milos V.
(@milos-v)
Re: Recalibrate with every new roll?
Depends on your problem. Different filament might need some small Z adjustment. But no need for calibration, you can tune this up at the print beginning from menu very fast.
Opublikowany : 04/11/2017 11:24 pm
ryan.f15
(@ryan-f15)
I'm concerned because I'm using something besides prusa filament and after a recalibration I'm at -.7mm and on the prusa roll I was at -.5. I'm also getting blobs:
Opublikowany : 05/11/2017 4:03 am
ryan.f15
(@ryan-f15)
End result
Opublikowany : 05/11/2017 4:34 am
ryan.f15
(@ryan-f15)
Same exact problem again. Dropped it to -1.5mm and got clicks. Raised it and clicks stopped bit I'm back to the sensor warnings. Do I just have a bad printer?
Opublikowany : 05/11/2017 7:03 am
Milos V.
(@milos-v)
The black filament is still PLA or ABS/PETG?
There is a significant difference in Z height between PLA and ABS or PETG. You have to adapt it when changing. Also there is a difference in printing temperatures in case you are trying to print Prusa logo from SD card with both filaments, it will not work.
Opublikowany : 05/11/2017 9:56 am
ryan.f15
(@ryan-f15)
No, in this case I'm using pla for everything.
Opublikowany : 05/11/2017 2:11 pm
