Random Y offset issue when extruder reach some Z
inoskyh
(@inoskyh)
Hello here,
I face an annoying issue while printing a custom 3D model: when my printer reach a certain Z value / layer, several random negative offset appear on Y axis. I started the print several times, regenerating STL / gcode each time, but always with the same issue in the end.
You can find the STL file here: https://www.dropbox.com/s/ni6zh2hh6znuqg2/structure.stl?dl=0
It is generated using OpenSCAD. I use latest prusa customized slic3r (1.8.0 - 28/07/17) to assemble parts and generated gcode. I also updated my Prusa i3 MK2 with the latest firmware (3.0.12 - 12/07/17).
I never observed this before after many prints, and I've done all the calibration several times.
I also printed objects that heigh (or above) with no problem.
Any idea?
Nicolas
Extra question: do you know any tips to suppress those filaments between edges? It's not really an issue since I can remove these using a cutter, but I'd prefer not have to!
Napsal : 12/08/2017 11:53 pm
AJS
 AJS
(@ajs)
Re: Random Y offset issue when extruder reach some Z
Some common causes are listed here:
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
Let us know if these don't help and we can help troubleshoot.
Napsal : 13/08/2017 3:45 am
inoskyh
(@inoskyh)
Ok, my "layer missaligned" problem looks very close to section "Print suddenly shifts in X or Y and keeps printing" in your Troubleshooting post.
I also noticed the "unsecured pulleys on the x and y axis" part in this video.
I checked things twice and started the print again, we'll see!
Thanks,
Nicolas
Napsal : 13/08/2017 12:35 pm
