Printing issue with larger prints
Hi all,
I received my Original Prusa last week and printed several things succesful, mostly the standard designs that come with the software.
But since yesterday I have a problem printing some larger objects, when getting a little bit higher (~20mm) the printing shifts slowly. Lower objects like the Batman don't have this problem, but for instance "Marvin" does.
I'm using PLA material.
Thanks for any help.
Alex
Re: Printing issue with larger prints
Hello Alex!
There is information in this link prusa-i3-kit-building-calibrating-first ... tml#p39190 describing common causes of layer shifting. Just scroll downwards a couple of lines. If there are no causes that fit your problem - please come with new findings - if any.
/Henrik
Hi Henrik,
Thanks for the link to that article, very helpful.
As a matter of fact the issue was caused of the filament spool couldn't run freely, the two holders were to tight. After giving this some more room the issue with moving x/y axis while printing didn't occur anymore.
Thanks again!
Alex
