printing head runs into the print
alb
 alb
(@alb)
I can only print about z=3.1 of the original print before the printer heads catches the print and starts shaking it. I just re-ran all calibration and tuning steps (no problem) what else can i do?
Publié : 26/06/2017 7:52 pm
AJS
 AJS
(@ajs)
Re: printing head runs into the print
Is this a packaged gcode, or one you sliced yourself?
Are you using Z-Lift?
Have you done an extruder calibration? Too much material can catch.
Is this PLA? What temperatures on extruder and bed?
Publié : 27/06/2017 2:44 am
alb
 alb
(@alb)
I sliced myself here is the file
  • tubing-3.gcode: https://drive.google.com/open?id=0B69k1LAvtUOLc3dROG50eXBfalk
  • Are you using Z-Lift?
    I don't know, here are the Slic3r config files:
  • print: https://drive.google.com/open?id=0B69k1LAvtUOLUkc4eTFDeTNZTGM
  • printer: https://drive.google.com/open?id=0B69k1LAvtUOLZm1zR3JuZnpwUjA
  • filament: https://drive.google.com/open?id=0B69k1LAvtUOLQ1NQNFh1VlVSSWc
  • Have you done an extruder calibration? Too much material can catch.
    I did, I went from 5mm@100 to 4mm@80 to 3mm@70 and still get this problem.
    It is PLA. Extruder at 215, bed at 55 (per gcode file).
    Publié : 27/06/2017 1:25 pm
    AJS
     AJS
    (@ajs)
    Does it have this bad behavior on one of the included files? Or only the one you sliced yourself?
    Publié : 27/06/2017 3:06 pm
    alb
     alb
    (@alb)
    resolved: careful calibration made the issue go away
    Publié : 27/07/2017 10:23 pm
