Printer resets a few minutes into printing
mikhail.c
(@mikhail-c)
Good day, im having a few problems regarding mi Prusa i3 Mk2S, yesterday it started restarting a few minuts into printing (2 or 3), then i updated the Firmware and printed a 5 hour model without a problem, but today it is restarting again, what could it be? Power? Heat?
Napsal : 06/10/2017 7:53 pm
AJS
 AJS
(@ajs)
Re: Printer resets a few minutes into printing
We need more details to help us.
Are you printing from the SD card or over USB?
What does it do when it "restarts"? Does the LCD say something?
Do you have good power where you live?
Napsal : 07/10/2017 1:44 am
mikhail.c
(@mikhail-c)
Yes, i print only from the card, power is fine, 110v and the switch is correct, the screen fills with squares that go away, much like when the x button on the front is pressed.
Napsal : 09/10/2017 5:22 pm
GertL
(@gertl)
A cable that gets shorted?
Maybe you can wiggle the cables and see if it happens,
Gert
Napsal : 09/10/2017 7:45 pm
