Print Failed and I found this Set Screw in the print
zachary.w
(@zachary-w)
Been printing in ABS. Printed this exact part twice before and was just printing a 3rd copy. Print was about 60% complete and then failed.
As I was cleaning it up and trying to figure out what happened I found this set screw in the print. I assume it fell out of the printer.
1. Where did it come from?
2. Can I fix this myself?
3. Why did this happen?
4. What else should I check before I resume printing?
Thanks guys!
-Zach
Opublikowany : 28/10/2017 12:34 am
bardiir
(@bardiir)
Re: Print Failed and I found this Set Screw in the print
This is probably the setscrew for the x-axis pulley. Just screw it back in there and maybe add a drop of screw-glue to it.
Opublikowany : 28/10/2017 1:18 am
or the Thermistor retaining screw for the hot end!
Opublikowany : 28/10/2017 1:53 am
