Previously Working Machine Won't Start, First STeps
Michael F
(@michael-f-2)
All;
It seems my prusa i3 mk2 is refusing to turn back on after attempting to raise the hotend temperature to remove a large glob of Proto-Pasta Magnetic Iron filament that had surrounded the hotend overnight.
I've gone through the standard procedure of unplugging/re-plugging the power cables and would appreciate some guidance on next steps.
Thanks,
Michael
Postato : 02/06/2017 12:29 am
Re: Previously Working Machine Won't Start, First STeps
if you dont get a display. chech the power supply output voltage and fuses
Postato : 02/06/2017 11:58 am
richard.l
(@richard-l)
Utenti Moderator
Michael,
Joan is correct. It is possible that the magnetic iron filament blob was able to cause a short across the heater wires. This will blow one of the fuses.
Postato : 02/06/2017 4:48 pm
Michael F
(@michael-f-2)
Richard & Joan;
I truly appreciate the advice, I plan on taking those steps after I've taken a few steps to remove that filament blob.
I will update this thread as I progress.
-Michael
Postato : 02/06/2017 5:54 pm
Michael F
(@michael-f-2)
Richard and Joan;
Hello again to you both, I've finally gotten around to testing my machine and... the hot end fuse did indeed fail.
After replacement and removal of the offending cables I was able to boot the machine again. I will now go to fix the remaining issue, but thank you for sending me on the right path.
Sincerely,
Michael
Postato : 07/07/2017 12:43 am
My pleasure.
Regards Joan
Postato : 07/07/2017 3:01 am
