Power consumption
Sheflya
(@sheflya)
Power consumption
Would adding a 11,2 W fan and approximately 1 meter of 12 V LED strip lights (not sure about power consumption) be an overkill for a MK2 power supply?
I read from various sources that MK2 doesn't really exceeds 200W power from it's 240W rated power supply. Would that be enough power reserve for power consumption peaks if fan and LED strip was added?
Napsal : 26/01/2018 11:45 am
Sheflya
(@sheflya)
Re: Power consumption
This LED strip for example: LINK
Napsal : 26/01/2018 11:52 am
Knickohr
(@knickohr)
Member Moderator
10W is no problem.
But keep in mind, if you're printing "hot" matierals, like Nylon with hot heatbed the power supply getting warm, maybe to warm. Specially if the printer is in a cabinet.
Thomas
Napsal : 26/01/2018 12:32 pm
Sheflya
(@sheflya)
Power supply will bit outside of the cabinet I'm building. I'll purchase 7W fan instead then and in combination with LEDs the consumption will be around 10W I think. thx
Napsal : 26/01/2018 1:52 pm
