possibly broken rambo mini
While plugging in all the cables I unintentionally mixed up the power cables from the PSU and the heater cables for the extruder and the bed. I turned it on and the lcd came on but the hotend started heating uncontrollably. I turned it off and discovered my mistake. when I switched the PSu cables and the extruder and bed cables the printer did not turn on indicated the dim LCD. any ideas?
Opublikowany : 22/01/2017 5:30 pm
Re: possibly broken rambo mini
Check all the fuses.
And you are not the first to do this...
Peter
Opublikowany : 22/01/2017 6:52 pm
