possibly broken rambo mini
williamk32
(@williamk32)
While plugging in all the cables I unintentionally mixed up the power cables from the PSU and the heater cables for the extruder and the bed. I turned it on and the lcd came on but the hotend started heating uncontrollably. I turned it off and discovered my mistake. when I switched the PSu cables and the extruder and bed cables the printer did not turn on indicated the dim LCD. any ideas?
Postato : 22/01/2017 5:30 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: possibly broken rambo mini
Check all the fuses.
And you are not the first to do this...
Peter
Postato : 22/01/2017 6:52 pm
