Pint failure on larger area print
Mao
 Mao
(@mao)
After printing successfully smaller items I tried to print larger items (picture 1). After a couple of hours print started to get severe increasing offset, first towards the back of printer and then also to the left. Then I stopped the print. See picture 2 for print detail!
What could be the cause of this? After the failure I printed the frog (50 microns) and it came out nicely.
This larger area of print is the affecting variable. But which part of the printer is failing?
Please can you help me? 🙁
Postato : 19/05/2017 11:07 am
murloc992
(@murloc992)
Re: Pint failure on larger area print
I had the same issue with a long print. Nozzle sometimes starts to grind on infill, sometimes so strongly that the nozzle gets stuck and belts skip/axis'es shift.
Postato : 19/05/2017 3:13 pm
phil.s2
(@phil-s2)
it definitely looks like the belts are slipping
did you hear any clicking sounds?
do you notice the belts wobbling when you are printing?
as the print head changes direction quickly do you see the belt wobbling
have you checked the printer for flatness? is it on a flat bed or desktop -do you keep moving it?
i did a post on belt tension
https://best3dprinter.stan-tech.com/3d-printer-belt-tension-is-it-important
i can also add that i am trying a suitcase scale to check belt tension -will keep you posted.
the other problem is warping of the model. if the fan is blowing too much and you are putting down thin layers these can warp upwards and catch the nozzle as stated above.
have you printed a large calibration model - only need to be 0.5mm thick but needs to cover most of the build platform?
helping others with 3d printer problems
building 3d printers
showing you can repair almost anything with a 3d printer and innovation - well, design!!
www.best3dprinter.stan-tech.com
Postato : 19/05/2017 4:13 pm
Mao
 Mao
(@mao)
I think that the belts are ok and no belt slipping is happening. Correct me if I am wrong but I believe that after belt slip on x & Y directions, next 9-point calibration would fail. And belt slip would happen on all prints. But but I have printed more objects successfully after that failure. My printer is on flat surface and I do not move it. I will try that large calibration test when I have time. But I have printed Bukobot Fly gliders successfully.
Postato : 22/05/2017 8:41 am
PJR
 PJR
(@pjr)
Antient Member Moderator
You are wrong and therefore I will do as you request 😉
At the start of a print, the axes are homed and their positions are reset prior to the 9-point calibration.
Slipping may not occur on all prints; this is something which happens mainly on larger prints although some small models are not immune from the problem.
A good thing to do is to limit the acceleration by inserting this in to the start GCode:
M201 X1000 Y1000 E600
Peter
Postato : 22/05/2017 9:48 am
Mao
 Mao
(@mao)
Thanks Peter! I think acceleration can be set also in Slic3r settings. What is the limit setting in your command row?
Postato : 23/05/2017 2:37 pm
PJR
 PJR
(@pjr)
Martti
The accelerations settings are as my previous post (the M201 command) but those are "safe" settings. My printers can handle values 50% more than stated.
The problem is that the default settings in the firmware are way too high (9000), the assumption being that the slicer will insert the acceleration commands where required. However not all slicers do tah and assume that the acceleration is set correctly within firmware...
Peter
Postato : 23/05/2017 2:46 pm
