PINDA cover
andy.b
(@andy-b)
PINDA cover
I am assembling the MK2 and in the extruder assembly steps http://manual.prusa3d.com/Guide/5.+Extruder+Assembly/114 it mentions a cover for the PINDA probe and if it wasn't included it can be printed from the printable parts http://www.prusa3d.com/prusa-i3-printable-parts/ . I noticed it isn't in the .zip file of printable parts. Do you guys recommend using it, and if so is there another place it is available?
Opublikowany : 12/08/2016 2:26 pm
3Delight
(@3delight)
Moderator Moderator
Re: PINDA cover
Some people think one helps others don't, it's a bit trial and error at the moment because it is a new feature...
If you want it, it is in the GitHub repository: https://github.com/prusa3d/Orignal-Prusa-i3/tree/MK2/Printed-Parts/stl
The file is called: PINDA_protector.stl
It is best to print it in ABS or PETG as it will be very near the hotend and could easily warp if done in PLA...
Opublikowany : 12/08/2016 4:17 pm
