Overextrusion at 0.35mm resolution
jonnieZG
(@jonniezg)
Even though my extruder is properly calibrated and I get great results with 0.10, 0.15, and 0.20 resolutions, there seems to be some massive overextrusion at 0.35 mm. I use Slic3r with default settings. Especially with infill lines that come between two walls. The filament builds up, making more than 0.5 mm protrusions up the Z-axis, making the head bump against it.
What can I do to fix that?
Thanks!
Napsal : 06/08/2017 8:24 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Overextrusion at 0.35mm resolution
Well, my best advice would be not to print layer heights greater than 75% (or at a push, 80%) of the nozzle diameter.
Peter
Napsal : 06/08/2017 8:37 pm
jonnieZG
(@jonniezg)
So it's not just me... Thanks, Peter, it makes perfect sense.
Regards,
Jonnie
Napsal : 06/08/2017 8:57 pm
