Original 3mm -> 1.75mm -> MK2 Upgrade
I've got an original 3mm printer which I have since upgraded to 1.75mm with the older kit. I talked to a support member a while back about upgrading this to the MK2 with the new upgrade kit, however they said it should be possible with a few changes. They mentioned that the 1.75mm printer had longer rods than the original 3mm, and possibly other changes but they weren't sure. They said if I were to order the upgrade kit, to add a PLA filament to the order and in the order comments to state "Please replace the PLA with any parts needed for the upgrade to a original 3mm kit that has been converted to 1.75mm". Does anyone know what else, if anything other than the rods differs here? And if anything will be different with the build process?
Postato : 08/11/2016 6:56 pm
