Nozzle Clogging
Patrik Rosén
(@patrik-rosen)
Nozzle Clogging
Hi!
I've printed 24/7 for a few weeks now without any issues. I was about to change unload the filament to fix some chaos on my Filament Spool, but what I was about to load the filament it seems like something has happened. The nozzle is heated, I've tried 210-250 degrees, but there is something stopping the filament in the hot end. The filament doesn't reach the nozzle, since its not melted at all when I unload after trying to load it. Maybe the teflon tubing has melted or something like that?
Anyhow, whats the best way to remove the hole hotend? I want to take it apart completely I guess. (remove nozzle from heatblock and the heatsink as well. I need to remove the fans and the motor right?
Best Regards Patrik
Me on 3dhubs!
Me on MyMiniFactory!
Me on Instagram
3D Printing Live Feeds
Prusa MK2 Usergroup Slack Live Chat
Unofficial live chat by users for users.
Veröffentlicht : 20/08/2016 2:44 pm
Shree Kumar
(@shree-kumar)
Re: Nozzle Clogging
Patrick,
It may not be necessary to open everything up. Can yoy see if the methods in http://shop.prusa3d.com/forum/original-prusa-i3-mk2-f23/my-method-of-clearing-the-filament-stuck-in-heat-b-t1148.html#p8657 work for you ?
HTH
-- Shree
Veröffentlicht : 20/08/2016 5:03 pm
Patrik Rosén
(@patrik-rosen)
Re: Nozzle Clogging
Great "guide", that helped! Although I needed to raise the nozzle temp to 240 before my heatsink started to get warm enough 🙂
Me on 3dhubs!
Me on Instagram
Veröffentlicht : 21/08/2016 11:47 am
christophe.p
(@christophe-p)
Mitglied Moderator
Re: Nozzle Clogging
In addition, you can consult this very interesting thread: http://shop.prusa3d.com/forum/original-prusa-i3-mk2-f23/extruder-completely-stuck-heat-didn-t-fix-it-t1117.html
To avoid this issue that I just had as well, gz1 advise to use a lower temperature (~170 °C) to unload filament, and I'm now following this advice.
I'm like Jon Snow, I know nothing.
Veröffentlicht : 21/08/2016 1:20 pm
Patrik Rosén
(@patrik-rosen)
Re: Nozzle Clogging
I think I had to much retraction as well, that might have caused it
Me on 3dhubs!
Me on Instagram
Veröffentlicht : 21/08/2016 2:04 pm
