Normal slope results???
turretbuddy2
(@turretbuddy2)
Been getting poor quality on slopes with supports on normal print setting (slightly modified) with PLA. Also had similar results on a slope with standard normal setting in Slic3r Prusa Edition. Is this normal or is something wrong with my printer or settings?
Close-up upside down view
Full (still upside down from initial print position)
Supports don't seem to help.
Postato : 28/06/2017 4:57 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Normal slope results???
Can you try printing the pre-sliced triceratops skull?
Here's the underside of mine after supports removed (sorry, it's black, but I can assure you it's pretty damned good... 🙂
Peter
Postato : 28/06/2017 10:24 pm
david.b14
(@david-b14)
Maybe the following will help:
- Slowing down the print.
- Adding a extra perimeter / wall
- increasing the flow / extrusion rate
Postato : 29/06/2017 1:29 am
turretbuddy2
(@turretbuddy2)
Thanks for the suggestions!
I'm going to print the triceratops from the SD card first. Though my filament reserves are quite low so I doubt I'll be able to finish it. Nevertheless, it should give a good indicator of the overhang quality.
Do you guys do anything different when working with sloping overhangs or just use the standard settings?
Tiger
Postato : 29/06/2017 11:33 am
PJR
 PJR
(@pjr)
Do you guys do anything different when working with sloping overhangs or just use the standard settings?Tiger
Well, I slice with KISS, but that's about the only difference - except that I also have the MM upgrade and therefore use Bowden tubes.
Peter
Postato : 29/06/2017 12:25 pm
turretbuddy2
(@turretbuddy2)
Ok here are the results!
Top
Bottom
Overall the quality is beyond what I expected so it definitely seems like a problem with the settings. Was the skull using the standard optimal print quality with supports?
Postato : 29/06/2017 3:49 pm
PJR
 PJR
(@pjr)
All the settings are at the start of the GCode file.
Looks to be 0.15mm but there are some modified settings; unfortunately I could not tell you what those are.
Peter
Postato : 29/06/2017 4:58 pm
turretbuddy2
(@turretbuddy2)
Thank you again!
As long as its not the printer then I can just change the settings.
Postato : 29/06/2017 6:48 pm
