Newbie Here - 1st print -- #failed
Kevin
(@kevin-16)
I got my Prusa Pre-assembled. went to print the Prusa Logo from SD card. After preheating the nozzle and calibrating the Z, I printed. However, it looks like the printed layer moved after several prints.. Do I need to spray somethign to have that 1st critical later set and not move?
Opublikowany : 27/02/2017 8:16 pm
JeffJordan
(@jeffjordan)
Member Moderator
Re: Newbie Here - 1st print -- #failed
💡 the first thing you need now is to get the correct z-live adjustment value right.
unfortunately the method with the v2calibration.gcode doesn't deliver viable results... 😥
it really drove me mad that i couldn't get the print stick to the highly acclaimed pei sheet surface and that i was never sure if the z-live value was correct, because sometimes the line of the v2calibration.gcode stuck very well at the surface but the print didn't stick at all. 😳
➡ after some analysis of the problem i found a procedure that leads to viable and reproducible results... and from the comments at the respective thread, i can see that it has helped a lot of users here. 😛
so have a look at this thread.
ps. i recommend the third gcode file i posted.
Opublikowany : 27/02/2017 8:32 pm
Kevin
(@kevin-16)
I'll try that this week! Thanks in advance
Opublikowany : 27/02/2017 9:36 pm
