Need Help!
nassar.s
(@nassar-s)
Need Help!
I sent an email to Prusa but have yet to receive a response.
  • I am having an issue. My MK2 loads Filament just fine, it flows through the bottom as it should.
  • When I start a print, it goes through the motions and puts done a thin line of test calibration filament on the side as it should, flow is fine.
  • Than it goes on to print and nothing flows, i held the filament and it does not move, the carriage makes a ticking sound.
  • I tried loading and unloading several times and this is a print which I have printed several times in the past.
  • Please help!
    Opublikowany : 13/12/2017 2:41 pm
    J Hyams
    (@j-hyams)
    Re: Need Help!
    Sounds like your hobbed pulley is slipping.
    Things to check:
    1. Make sure it is aligned with the nozzle entrance (ptfe tube) and tighten the grub screw.
    2. Make sure you clip the filament to a sharp point when you load.
    3. Check to see if the head is reaching and maintaining temperature.
    Side:
    I have read some users have success with lubricating the filament (you will need to google for the specifics)
    Addition:
    I have no clue why you would have a feed slipping problem for print only when the purge line is fine.
    Opublikowany : 13/12/2017 3:50 pm
    GertL
    (@gertl)
    Re: Need Help!
    Could attach a picture of above?
    Maybe you are very close to the bed with the nozzle that it have a hard time pushing something out.
    The priming line (if this is what you mean by above) should be fairly wide, at least the last centimeter or so.
    Gert
    Opublikowany : 13/12/2017 3:56 pm
