Mk2s + multi-material upgrade, which first?
My mk2s and multi-material upgrade has shipped. Which one do I do first? Are there any gotchas I should be aware of before starting?
Re: Mk2s + multi-material upgrade, which first?
Mk2S upgrade first. Be patient; print for a couple of days and then add the MM upgrade.
Peter
Good idea thanks! I always rush things...
FWIW, the only thing I changed on my Mk2 was the cable management at the back of the extruder and while it was in bits, I changed the X bearings.
Peter
