MK2.5 Multi Material?
mbleeker
(@mbleeker)
I have a MK2 printer and I was just about to purchase the MMU for the MK2. I know MMU for the MK3 will eventually be released in the coming months but I was wondering if there will be an exclusive MK2.5 MMU?
If not, is it safe to go for the MK2.5 and the MK2 MMU with the assumption that the 2.5 MMU modifications will largely be printable?
Opublikowany : 12/10/2017 8:08 pm
Milhooz
(@milhooz)
Re: MK2.5 Multi Material?
I have the MK2S and MMU and I hope I will be able to update my MMU, for now, to get the 2.5 upgrade, I will wait to get a clear answer about if it's going to be possible without too much expense. Bed, Pinda, Noctua and part cooling fan should pose no issue because they are unrelated to MMU but filament sensor will need updated extruder blocks and electronics.
Opublikowany : 14/10/2017 12:06 pm
BeNe
 BeNe
(@bene)
I found an information here --> https://shop.prusa3d.com/forum/original-prusa-i3-mk3-f30/mk3-multi-material-t6193.html#p43452
Opublikowany : 14/10/2017 10:51 pm
