Mk2 won't calibrate anymore "Consult Manual"
Uenbzsto
(@uenbzsto)
Formerly healthy Mk2 now won't complete calibration. I'm looking for ideas on what to check next, particularly any ideas on how to verify that I don't have a component failure that isn't getting picked up by the self test. Appreciate any ideas on what the issue is or what steps I should take next to debug this.
Here's all the info I can pull together:
  • Prusa i3 Mk2 printer kit (received January 2017)
  • Rambo13a
  • 258.32m filament
  • 5d:12h:21m print time
  • Firmware 3.0.12
  • Self test OK
    XYZ calibration:
  • completes "Searching for bed calibration point" Iteration 1 and 2 (4 of 4)
  • sometimes goes to iteration 3
  • sometimes goes to and completes Improving calibration point sequence (9 of 9)
  • then fails "consult manual"
  • Y distance from min:
    Left: N/A
    Center: N/A
    Right: N/A
    Measured skew: N/A
    Noted PINDA probe light is on during calibration
    History:
    I think the initial firmware I loaded during assembly was 3.0.10
    Initial calibration with no misalignment
    Printed flawlessly for the first ~24 hours of printing
    Found y axis had been misaligned and caused belt rubbing. Replaced belt and fixed misalignment
    Upgraded to 3.0.11
    Noted scraping noise on x axis in the bearings
    Began failing prints, usually due to missed steps on x axis but sometimes due to missed steps on y axis
    Switched to high power mode
    Lubricated x axis rails and idler pulley with silicone spray
    Reduced print speed and acceleration by 50%
    Printed ok for ~24 hrs of printing
    Began failing prints again
    First layer height became uneven
    Found scratches on the print bed
    Attempted to recalibrate
    Failed calibration "consult manual"
    Noticed PINDA probe retention nut was loose, tightened it
    Checked axis alignment visually and with an INCRA square
    Checked axis movement
    Looked for signs of belt rubbing
    Lowered PINDA probe slightly
    Sometimes gets to 1 of 9 calibration points but usually fails after completing the first 4 points
    Flashed 3.0.12-RC2
    Flashed 3.0.12
    Flashed 3.0.10
    Flashed 3.0.12
    Noted some y axis bearing scraping noise
    Do not see any loose fasteners or signs of belt rubbing
    Lubricated y axis bearings and idler with silicone spray
    Still fails calibration
    Publié : 23/07/2017 6:18 pm
    AJS
     AJS
    (@ajs)
    Re: Mk2 won't calibrate anymore "Consult Manual"
    It sounds like the PINDA probe is too high. It should be <1mm higher than the nozzle tip. 0.6mm (about the thickness of a credit card) should be close enough to trigger, but hi enough not to catch on the print.
    Publié : 24/07/2017 5:02 am
    Uenbzsto
    (@uenbzsto)
    Thanks for the suggestion. I lowered the probe in several increments and retried XYZ cal until now it's even with the nozzle tip. Still getting the same result though.
    Publié : 28/07/2017 2:06 am
    AJS
     AJS
    (@ajs)
    During the calibration, is it searching in the correct area? (above the circle)?
    Is the PINDA light on? Does it ever click off?
    Publié : 28/07/2017 4:32 am
    Uenbzsto
    (@uenbzsto)
    The printer seems to be going to all the correct spots on the print bed, and the PINDA probe seems to be working. For example if I tell it to auto-home, it has no problem finding the Z axis position.
    Yes the PINDA light is on, and blinks off occasionally during the cal process.
    Publié : 28/07/2017 1:00 pm
    AJS
     AJS
    (@ajs)
    I am grasping at straws, but when you only have straws, you grab them.
    Try rolling back to an older version of the firmware. The calibration process changed a lot in .12, and see if the older version works for you. That might help pinpoint the issue.
    Publié : 28/07/2017 3:05 pm
    Uenbzsto
    (@uenbzsto)
    I was initially on 0.11 when I started having failed prints, and then updated to 0.12 to try to fix the subsequent failed re-calibration attempt (see my troubleshooting log in my original post). I also rolled back as far as 0.10 with no luck, and before the issues started I previously had a decent run of prints on 0.10 without issues.
    My working theory is that I'm still skipping steps on either the x axis, the y axis, or both. But I don't know how to verify whether that's happening, or if that's a likely cause of failed calibration with the "consult manual" output.
    Is there a way to dig farther into where in the calibration function's state machine things are going wrong?
    Maybe some way to get verbose output via the USB link?
    Do I need to start hacking the firmware?
    If I have an X axis rail misalignment causing excessive drag, is there any way to fix it?
    Why would something have changed over ~5 days of operation?
    Could the bearings have gone bad in that short of a time?
    Publié : 28/07/2017 7:00 pm
    slippyr4
    (@slippyr4)
    Do the calibration from pronterface with M45 V2 and then paste the results
    Publié : 28/07/2017 11:17 pm
    Uenbzsto
    (@uenbzsto)
    Here's the Pronterface output. Failed "consult manual" after 3rd iteration of 4 point calibration.
    >>>M45 V2
    SENDING:M45 V2
    Iteration: 1
    correction angles: 0.08199, 0.14318
    X vector, adjusted: 1.00000, -0.00143
    Y vector, adjusted: 0.00250, 1.00000
    center, adjusted: -1.02897, 0.39039
    Difference after correction:
    point #0measured: (113.34000, -1.46000); measured-corrected: (112.96574, -1.77275); target: (114.00000, -2.00000), error: 0.49
    point #1measured: (213.36000, 96.10000); measured-corrected: (214.21037, 96.08267); target: (215.00000, 96.00000), error: 0.85
    point #2measured: (113.67000, 194.16000); measured-corrected: (113.45554, 194.22715); target: (114.00000, 194.00000), error: 0.22
    point #3measured: (11.63000, 96.39000); measured-corrected: (11.21090, 96.37318); target: (12.00000, 96.00000), error: 0.42
    Iteration: 2
    correction angles: 0.08568, 0.15377
    X vector, adjusted: 1.00000, -0.00150
    Y vector, adjusted: 0.00268, 1.00000
    center, adjusted: -1.00949, 0.36539
    point #0measured: (113.35250, -1.48125); measured-corrected: (112.98481, -1.80508); target: (114.00000, -2.00000), error: 0.49
    point #1measured: (213.36999, 96.08500); measured-corrected: (214.24754, 96.04384); target: (215.00000, 96.00000), error: 0.88
    point #2measured: (113.72000, 194.08000); measured-corrected: (113.51084, 194.19485); target: (114.00000, 194.00000), error: 0.24
    point #3measured: (11.70500, 96.38750); measured-corrected: (11.24812, 96.34741); target: (12.00000, 96.00000), error: 0.46
    Iteration: 3
    correction angles: 0.10327, 0.03780
    X vector, adjusted: 1.00000, -0.00180
    Y vector, adjusted: 0.00066, 1.00000
    center, adjusted: -0.87172, 0.35260
    point #0measured: (113.36333, -1.47500); measured-corrected: (113.12702, -1.85287); target: (114.00000, -2.00000), error: 0.45
    point #1measured: (213.38333, 96.01834); measured-corrected: (214.19172, 95.96500); target: (215.00000, 96.00000), error: 0.81
    point #2measured: (113.39000, 194.00167); measured-corrected: (113.25633, 194.14694); target: (114.00000, 194.00000), error: 0.20
    point #3measured: (11.73000, 96.38333); measured-corrected: (11.19163, 96.33088); target: (12.00000, 96.00000), error: 0.54
    Publié : 19/08/2017 12:23 pm
    Uenbzsto
    (@uenbzsto)
    I just found damage on the X axis belt. I will report back if replacing that fixes the issue.
    Publié : 19/08/2017 12:34 pm
    Uenbzsto
    (@uenbzsto)
    Well, that was it. I had previously inspected both belts, but apparently missed a stretched section on the X belt. After replacing the belt, calibrated on the first try.
    >>>M45 V2
    SENDING:M45 V2
    Iteration: 1
    correction angles: 0.09323, 0.10180
    Very little skew detected. Orthogonalizing the axes.
    X vector, adjusted: 1.00000, -0.00170
    Y vector, adjusted: 0.00170, 1.00000
    center, adjusted: -0.47729, 0.44137
    point #0measured: (113.49500, -1.41250); measured-corrected: (113.51915, -1.75265); target: (114.00000, -2.00000), error: 0.34
    point #1measured: (214.80000, 96.09500); measured-corrected: (214.68580, 96.07531); target: (215.00000, 96.00000), error: 0.12
    point #2measured: (113.85000, 194.17999); measured-corrected: (113.85274, 194.24707); target: (114.00000, 194.00000), error: 0.07
    point #3measured: (11.59000, 96.42501); measured-corrected: (11.68609, 96.42081); target: (12.00000, 96.00000), error: 0.10
    correction angles: 0.08994, 0.08852
    X vector, adjusted: 1.00000, -0.00156
    Y vector, adjusted: 0.00156, 1.00000
    center, adjusted: -0.43139, 0.33947
    point #0measured: (11.53250, -1.26188); measured-corrected: (11.56548, -1.67922); target: (12.00000, -2.00000), error: 0.42
    point #1measured: (113.59500, -1.50125); measured-corrected: (113.56536, -1.83806); target: (114.00000, -2.00000), error: 0.34
    point #2measured: (214.61999, -1.29500); measured-corrected: (214.56523, -1.99535); target: (215.00000, -2.00000), error: 0.70
    point #3measured: (214.77000, 95.93875); measured-corrected: (214.71784, 96.00453); target: (215.00000, 96.00000), error: 0.08
    point #4measured: (113.70250, 96.16750); measured-corrected: (113.71798, 96.16182); target: (114.00000, 96.00000), error: 0.02
    point #5measured: (11.62500, 96.24875); measured-corrected: (11.71810, 96.32067); target: (12.00000, 96.00000), error: 0.12
    point #6measured: (11.76500, 194.34873); measured-corrected: (11.87071, 194.32054); target: (12.00000, 194.00000), error: 0.11
    point #7measured: (113.86000, 194.08499); measured-corrected: (113.87059, 194.16169); target: (114.00000, 194.00000), error: 0.08
    point #8measured: (215.01000, 193.98873); measured-corrected: (214.87046, 194.00440); target: (215.00000, 194.00000), error: 0.14
    Publié : 19/08/2017 1:16 pm
