        MINTEMP
Hey my printer is showing a mintemp error and cannot get the temp to be shown correctly. I read around a bit and tried resetting it, using a heat gun but none of that is currently working. It starting doing this after the distance sensor fell off and a whole bunch of PLA built up on the executor. What should I try doing?
                            Posted : 25/02/2018 2:56 am
                    Re: MINTEMP
If your nozzle temperature shows 0°C, the wires to your hotend thermistor were probably damaged when you had the PLA buildup on your extruder.
See this thread for more info: https://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/err-mintemp-solved--t36.html#p67727
-Kevin
                            Posted : 25/02/2018 3:35 am
