Mildew on PLA printed parts?
coolRR
(@coolrr)
Hey dudes,
I'm very confused right now. I've printed a "mouse bungee" for a friend of mine. I designed the body as a hollow cylinder, and poured concrete inside of it to make it heavy, so it wouldn't move when using the mouse. This is my second time pouring concrete into a print, after the first time was a success.
The concrete hardened, and the piece is indeed heavy, but it has these white spots on the outside:
It looks like mildew, but I can't be sure. I washed it off, and then it appears again. I thought that at some point it's going to stop, but it didn't. For the last 5 days I've been washing it off, sometimes with water, sometimes with alcohol and sometimes with dishwashing liquid, but it comes right back after a few hours.
Do you think it's indeed mildew? Any idea why that would happen? Any way to get rid of it without having it come back again?
Thanks for your help,
Ram Rachum.
Napsal : 31/08/2017 12:02 pm
Neal
 Neal
(@neal-3)
Re: Mildew on PLA printed parts?
Maybe a small (really minute) bit of concrete seeped out between layers and stained it.
Neal
Napsal : 31/08/2017 2:53 pm
AJS
 AJS
(@ajs)
I have no experience with this, I have just been thinking about it.
When concrete drys, it puts out a lot of water. PLA is biodegradable. If the PLA, in this constantly moist state starts to biodegrade, that would make a very nice environment for molds and mildews (food+water).
Once it drys thing should be better, but once you start a process like that, it tends to keep going.
At paint stores they sell small paint additives to prevent mold and mildew (e.g. if you are painting a bathroom or other humid room). Such an additive to the concrete should prevent this process from starting.
I am curious. While PLA is basically corn starch with some additives, which seems like it would be safe for the little guys to chew on (the gnaw on everything), I was wondering if you had done any research for filament that are chewing pet friendly.
Napsal : 01/09/2017 4:31 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Well I have had PLA printed plant holders inside a fish tank for over 6 months and a printed fish tank lid for about 8 months. No sign of any degradation. Only thing I have seen on the lid is white calcium deposits from the water as it dries.
Peter
Napsal : 01/09/2017 4:50 pm
coolRR
(@coolrr)
Thanks for your input guys!
I have not, sorry.
Napsal : 01/09/2017 5:29 pm
walter.l
(@walter-l)
I am new to 3d printing, but I have some experience with concrete. I think it could be Efflorescence, which is a common problem when working with concrete. I think there are some products available at the hardware store, to remove it.
Napsal : 06/09/2017 2:07 am
coolRR
(@coolrr)
Thank you Walter! I'll check it out.
Napsal : 06/09/2017 9:00 am
