Melted heat bed connector
ed.y
 ed.y
(@ed-y)
My heat bed had issues when heating to 100C, so I decided to check out the connector to the board.
Turns out it had melted 👿 . I've managed to clean out the melted plastic on the pens in the board.
Is it still recommended that the heated bed should be soldered to the board, or can I replace the terminal block? If I need to should does it matter which way round the wires need to be soldered. I assume red wire is +ve?
Also my soldering is not great, so is there an alternative to prevent this from happening?
Respondido : 14/05/2017 10:12 am
