Loosened wires from extruder
Veetyaz
(@veetyaz)
Hi - I had a bed adherence issue on my last print, so the nozzle ended up dragging the print around with it, creating a massive clog all over the extruder, which eventually dislodged the blue wires out from the extruder. That seemed to then cause a runaway heat issue. So it was fun.
My absolutely newbie question - how bad is this and how do I fix it? Do I need to replace the extruder or extruder motor? Also, I'm slightly worried about messing with it, since I bought it assembled and am concerned that I'll break it worse.
Any help or advice appreciated!
Opublikowany : 07/01/2017 1:54 pm
StephanK
(@stephank)
Re: Loosened wires from extruder
Can you post a picture of how it looks? Kinda hard to diagnose without seeing..
Opublikowany : 07/01/2017 2:38 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Marc
Blue wires are for the thermistor; these were broken which resulted in the thermal runaway error.
You will need to at least replace the thermistor, the most likely one for your printer is this: http://e3d-online.com/Electrical/Components/Thermistor-Cartridge
Peter
Opublikowany : 07/01/2017 6:11 pm
Veetyaz
(@veetyaz)
Peter,
Thanks very much. I'll try disassembling the extruder assembly. Hopefully, it's just the thermistor. It looks like it pulled out of the extruder motor, so I'm hoping it's simple.
On a related point, I'd welcome your thoughts and those of others on the underlying first layer adhesion issue. My only luck has been to use the glue stick pretty heavily. I get almost no adhesion just with the bed itself. Others have suggested hairspray? Even when I get it to stick, I end up getting pretty heavy warping, which makes me wonder if the room itself is too cold.
Anyway, thanks again for the answer!
Opublikowany : 09/01/2017 9:11 pm
