Layer height
Guardian_DE
(@guardian_de)
Layer height
What are the allowed and recommended layer heights for a stock MK2?
Josef has 0.05mm, 0.10mm, 0.20mm and 0.35mm in the Slic3r profile. Now I'd like to print stuff with a 0.50mm layer height. Is that possible and is it recommended?
Postato : 16/08/2016 4:30 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Layer height
Jan
Anything is possible... If it works for you then great.
There is a general recommendation that the layer height should be at most 80% of the nozzle diameter, but going more than the 80% will probably only result in poor print quality.
Peter
Postato : 16/08/2016 5:43 pm
pbnj
 pbnj
(@pbnj)
Re: Layer height
Change nozzle size, I use a .8mm nozzle with a .64 line width. If you change to a .6mm Nozzle you can get what you want.
Postato : 16/08/2016 6:49 pm
