Is this bed temp variation normal?
Rutilate
(@rutilate)
Folks,
I'm attempting to diagnose poor bed adhesion. Are bed hotspots and bed temperature variations from 52C-57C normal and expected?
I've used an FLIR attachment for my phone to capture a thermal image of the heated MK2 bed:
The front of the bed is to the left of the photo.
And here are the max/min temps:
As you can see, it appears that the bed is heated fairly well, with a hotspot in the front right corner. The minimum temp is 52.2, and max is 57.
Is that variation expected? is the location of the hotspot expected?
Postato : 16/07/2016 2:41 am
Mf90
 Mf90
(@mf90)
Re: Is this bed temp variation normal?
That looks pretty good to be fair. The glass topped beds I've used would drop off dramatically on three sides making large prints a total test of faith.
What are your adhesion problems? Has this variance led to warping in the lower temperature areas?
Postato : 16/07/2016 2:50 am
Rutilate
(@rutilate)
Michael,
Thanks for the response. I'm not sure how much is bed adhesion vs. under extrusion vs. temp derived. I'm having to live adjust my Z way too low in order to get bed adhesion:
The first layer is nearly translucent and even still, some of the lines are discrete.
When I print the Adalinda model, the claws are a mess:
I've rebuilt xy, leveled, calibrated xy & z with the latest firmware, cleaned the bed with alcohol, tried glue, nothing. I get quite good adhesion when I crank the nozzle temp to 230 but then I get a low-temp thermal runaway shutdown on the 2nd or 3rd layer of Adalinda as the nozzle temps plummet.
Postato : 16/07/2016 3:00 am
Mf90
 Mf90
(@mf90)
that sounds super frustrating. You're working through all the right tests though.
Have you tried a lower layer height for the first layer?
I've found that squeezing a thicker layer flat with the z-adjust doesn't work as I'd expect and tends to curl up.
Postato : 16/07/2016 11:55 am
