Info screen print time - bug or feature?
devilhunter
(@devilhunter)
I don't quite get the meaning behind the time counter on the info screen.
It continues to run even if the print finished; like i start a 4 hour print on Friday evening, and check back on Monday morning, it will display something about 50-60+ hours.
Is there a reason this counter has a "time since this print job was started" behavior?
Wouldn't a "print time for this print" counter make more sense?
Opublikowany : 11/02/2017 3:14 pm
JeffJordan
(@jeffjordan)
Member Moderator
Re: Info screen print time - bug or feature?
💡 have a closer look at the screen:
➡ you can see two timer values ❗
at the end of row#3 you can see the time that has past after the last print.
but at row#4 you can read the time it took to print.
yes, of course. that's what the 4th row will show you.
so it's no bug, it's a feature :mrgreen:
Opublikowany : 12/02/2017 11:23 am
