Improving print quality on corners
andy.b
(@andy-b)
Below is a picture of a print I am doing and when it turns the corner it seems to overshoot the turn and then come back to the line. I also notice this in another area where it makes a turn and then the printhead seems to resonate for a few mm before getting back on a straight line. The way I am holding the print is the same way it sits on the printbed with the straight side perpendicular to the x axis. Any tips would be appreciated.
Publié : 15/08/2016 3:13 am
martin.w3
(@martin-w3)
Re: Improving print quality on corners
Have you tried printing at a slower speed?
Publié : 15/08/2016 8:33 am
Ben
 Ben
(@ben)
Yes if running at 100% try taking it down to 80% using the knob while running. I find 75%-85% is the butter zone for great prints. However even at 100% they are still good results.
Another option is to take your flow down to around 95% - 97%
Publié : 15/08/2016 8:40 am
andy.b
(@andy-b)
I hadn't, I was using the stock speed from the simplify 3D settings
Publié : 15/08/2016 12:31 pm
David T.
(@david-t)
S3D by default doesn't handle acceleration control at all. I recommend using the settings dealing with acceleration. For example, you can use something like
{REPLACE "; outer perimeter\n" "; outer perimeter\nM204 S800\n"}
{REPLACE "; inner perimeter\n" "; inner perimeter\nM204 S800\n"}
{REPLACE "; solid layer\n" "; solid layer\nM204 S1000\n"}
{REPLACE "; infill\n" "; infill\nM204 S2000\n"}
in Additional terminal commands for postprocessing.
Publié : 15/08/2016 12:51 pm
andy.b
(@andy-b)
Do you know where I can find the stock acceleration settings?
Publié : 15/08/2016 2:23 pm
David T.
(@david-t)
I'm not quite sure about what do you mean by "stock acceleration settings". S3D hasn't got any setting specially for acceleration. You will have to either specify acceleration in the starting gcode (generally for whole print) or set it more special in postprocessing.
The adjustment I've recommended is based on values provided in PR's default profiles for Slic3r and works well for me. I should say I also use the same speeds as defined in Slic3r profiles. In fact I use Slic3r most of the time, S3D only for prints where I need some special features.
Publié : 15/08/2016 3:21 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
For other slicers, you could try inserting the following line into the start GCode:
M201 X1000 Y1000 E600 ; set default acceleration
This is as suggested by Josef, but I have pushed all values by 50% on a Mk1 without issue (when printing @ 180mm/sec with some testing I did a while back).
Peter
Publié : 15/08/2016 4:04 pm
