i3Mk2 Set up and Calibration
mortimer.r2
(@mortimer-r2)
I ordered the i3 Mk2 as soon as it became available, hoping for a well made, stable machine with the benefits of a large print area, auto calibration of Z axis and a metal frame. I assembled it one week ago, and am still trying to make it work consistently, and to get it basically calibrated. I am an experienced user and maker of reprap style printers, so the only thing new to me here is the metal frame and the auto bed levelling. I have done everything suggested in the manual and help videos and followed the forums for advice, but still cannot get the bed 'level' or achieve a consistent printing experience - I have spent at least 40 hours on this so far. As suggested in other forum posts, I have made a video showing aspects of my setup experience, available here:
http://sendvid.com/v1kso01y
...if I've missed anything, or there is any advice anyone can give me, I would be very grateful.
Mortimer
UK
Napsal : 05/06/2016 12:11 pm
Keri
 Keri
(@keri)
Re: i3Mk2 Set up and Calibration
Hi!
I can't give you any advice but I am mostly in the same boat. I have spent so much time calibrating this printer and have had little or no luck. I too bought this to be a stable good quality printer and have not seen that come to fruition. At the end of your video you said that when you get to your printer the issues are always different, and I agree with that statement! It'll work in one moment and not in the next.
Good luck in your endeavors!
Napsal : 05/06/2016 4:11 pm
michalprusa
(@michalprusa)
Member Admin
Mortimer
UK
Hello Mortimer,
can you please post here your V2 calibration you have on your SD card? Also what version of firmware you have?
Michal Prusa
CTO
Napsal : 05/06/2016 5:21 pm
mortimer.r2
(@mortimer-r2)
Hello Michal
Firmware:
1_75mm_MK2-RAMBo13-E3Dv6full
Thanks for your response so quickly.
Mortimer
This is the v2 calibration gcode your support team sent to me by email (which I think is the same as the one I already had):
M107
M104 S210
M140 S55
M190 S55
M109 S210
G87
G88
G28
G92 E0.0
G1 X60.0 E9.0 F1000.0
G1 X100.0 E12.5 F1000.0
G92 E0.0
G21 ; set units to millimeters
M83 ; use relative distances for extrusion
G1 E-1.50000 F2100.00000
G1 Z0.150 F7200.000
M204 S1000
G1 F4000
G1 X50 Y155
G1 F1080
G1 X75 Y155 E2.5
G1 X100 Y155 E2
G1 X200 Y155 E2.62773
G1 X200 Y135 E0.66174
G1 X50 Y135 E3.62773
G1 X50 Y115 E0.49386
G1 X200 Y115 E3.62773
G1 X200 Y95 E0.49386
G1 X50 Y95 E3.62773
G1 X50 Y75 E0.49386
G1 X200 Y75 E3.62773
G1 X200 Y55 E0.49386
G1 X50 Y55 E3.62773
G1 E-0.07500 F2100.00000
M107
M104 S0 ; turn off temperature
M140 S0 ; turn off heatbed
G1 X10 Y180 F4000 ; home X axis
G1 Z10 F1300.000
M84 ; disable motors
Napsal : 05/06/2016 8:18 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Hi Mortimer
I think you have written a rather conflicting sentence there; had you wanted a well made, stable printer then surely you would have purchased the Mk1 and not the Mk2 with all the new features which have not as yet been fully tested by users?
Unfortunately, Prusa Research have (for whatever reason) released kits to new users rather than upgrades to existing and very happy users. This has meant that very few of us that knew just about everything to know about the Mk1 can't help much with the Mk2.
What I will say is that when you sort out your problems, I am very confident that you will find the Mk 2 to be the best printer you own.
Peter
Napsal : 05/06/2016 8:56 pm
michalprusa
(@michalprusa)
Member Admin
Hello Michal
Firmware:
Mortimer
M107
M104 S210
M140 S55
M190 S55
M109 S210
G87
G88
G28
G92 E0.0
G92 E0.0
G1 Z0.150 F7200.000
M204 S1000
G1 F4000
G1 X50 Y155
G1 F1080
G1 X75 Y155 E2.5
G1 X100 Y155 E2
G1 X50 Y95 E3.62773
G1 X50 Y75 E0.49386
G1 X50 Y55 E3.62773
M107
G1 Z10 F1300.000
Hello Mortimer,
the g-code looks ok, can you try to flash this firmware "1_75mm_MK2-RAMBo13a-E3Dv6full.hex" ( https://github.com/prusa3d/Prusa-Firmware/tree/MK2/hex_files )? It's the most recent one available only on github at the moment.
Michal Prusa
CTO
Napsal : 05/06/2016 9:13 pm
pbnj
 pbnj
(@pbnj)
I notice on the screen that you had the motors set to silent mode. This mode is a know problem. Try it on the other setting. Maybe you are missing a step or two.
JB
Napsal : 06/06/2016 7:16 pm
