How do you get good first layer height consistency?
alexw
(@alexw)
I've been working on a few prints lately that require fine-tuning the first layer, and therefore good consistency from print to print to get the same results. I'm finding that I dial in the live Z adjust to get the perfect .2mm first layer dictated by my slicer, but then the very next print will suddenly have a .26mm first layer with bad under-extrusion. Is there any way to fix this besides waiting for the new temp-compensated probe in the 2.5 upgrade kit? Does any particular workflow work for consistent first layer height, like "start the print cold and make sure your slicer doesn't pre-heat"?
Postato : 02/11/2017 12:53 am
alexw
(@alexw)
Re: How do you get good first layer height consistency?
Can I assume the silence means nobody ever gets good first layer consistency?
Postato : 04/11/2017 8:56 pm
AJS
 AJS
(@ajs)
I get perfectly good consistency.
The common solution to this is to make sure the PINDA probe is at a higher Z value during the warm up pre calibration.
Most people have modified their "before print gcode" to only heat to a lower temp (to prevent drips) before the calibration, ands to do the warm up with a higher Z value. Something like this:
M115 U3.0.12 ; tell printer latest fw version
G21 ; set units to millimeters
M83 ; extruder relative mode
M104 S170; Extruder to 170
M140 S[first_layer_bed_temperature] ; set bed temp
G1 X0 Y0 Z125; home X axis Lift to 125
M190 S[first_layer_bed_temperature] ; wait for bed temp
M109 S170 ; wait for extruder temp to hit 170
M104 S[first_layer_temperature] ; set extruder temp
G80 ; mesh bed leveling while rising in temp
G1 Y-3.0 F1000.0 ; go outside printing area
M109 S[first_layer_temperature] ; wait for extruder temp if needed
G92 E0 ; reset extrusion distance
G1 X100.0 E9.0 F1000.0 ; intro line
G1 X200.0 E12.5 F1000.0 ; intro line
Postato : 04/11/2017 9:24 pm
alexw
(@alexw)
What is the intended result of that sequence - to do the mesh leveling with the probe not as hot as it would be sitting low over the warm bed?
Assuming it was temperature drift related, I adjusted the Z height for consistently running the print start (and mesh leveling) at full bed temp with the probe warmed up. I figured that was the only way to assume the probe would be at a consistent temperature, since doing it cold-cold would have only behaved consistently for the first print of the day.
I guess I'll try that start sequence though.
Postato : 08/11/2017 10:55 pm
alexw
(@alexw)
Okay - comparing to my current code in Cura:
G90 ; use absolute positioning
M82 ; absolute extrusion mode
M104 S{material_print_temperature} ; set extruder temp
M140 S{material_bed_temperature} ; set bed temp
M190 S{material_bed_temperature} ; wait for bed temp
M109 S{material_print_temperature} ; wait for extruder temp
G92 E0.0 ; reset extruder distance position
G1 Y-3.0 F1000.0 ; go outside print area
G1 X100.0 E21.5 F1000.0 ; intro line
Most of it just looks like re-sequencing. But my current code uses M82 absolute extruder mode, rather than M83 relative mode. Is that something I shouldn't change when copying yours?
Postato : 09/11/2017 12:03 am
alexw
(@alexw)
So I think that code must be for Slic3r, and the cura syntax is a little different. After some digging, I finally settled on this, which does everything you mentioned. Hopefully it'll sort out my print-to-print variability.
; New code for Cura
G1 X0 Y0 Z100; home X axis Lift to 100
M140 S{material_bed_temperature_layer_0} ; set bed temp
M190 S{material_bed_temperature_layer_0} ; wait for bed temp
G80 ; mesh bed leveling while extruder is rising to 170 (though it's probably there by now)
M104 S{material_print_temperature_layer_0} ; set extruder temp
M109 S{material_print_temperature_layer_0} ; wait for extruder temp
Postato : 09/11/2017 2:15 am
