How do I avoid this pattern?
jernst
(@jernst)
This is the first layer of a print. It started printing from the top-left corner, where everything looks just fine. But then, as we get to the middle, the print becomes "wavy".
Any ideas what might cause this? And what I can do to prevent it?
Posted : 12/12/2017 12:06 am
rob.l6
(@rob-l6)
Re: How do I avoid this pattern?
Perhaps your bed isn't uniformly level.
Have you tried different z adjustments? I would back off a little on the z level and try it again.
Posted : 12/12/2017 5:24 am
Andy
 Andy
(@andy-12)
The front right of the heat bed seems lower than the rest of the bed. The auto calibration hopefully should correct, if not check that the bed is connected to the Y structure securely. The wavy print is because the nozzle is too far from the bed. Have you tried the active Z adjustment while printing?
Original Prusa I3 MK2s with 2.5 upgrade; Original Prusa I3 MK3s; Slic3rPE; FreeCAD
Posted : 13/12/2017 7:50 pm
GertL
(@gertl)
To me it looks like you are to close to the bed, it can be hard to tell from a picture though.
Have look at this thread, it helps a lot to get the first layer just perfect.
https://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/life-adjust-z-my-way-t2981.html#p50038
Gert
Posted : 13/12/2017 9:25 pm
