Hotend thermistor not changing
David Wybourn
(@david-wybourn)
I recently moved my printer so decided to run self test and calibration again, all worked fine. However, when trying to print I noticed that the hotend temperature was not changing and stays at a constant 23 degrees.
I can feel heat coming off the hotend so it must be a thermistor problem. My question is why did the self test pass? I ran it twice and both times it passed.
Also, why would a broken thermistor give a fixed value, surely it would give no value?
Thanks
Opublikowany : 03/03/2017 9:12 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Hotend thermistor not changing
Question: Is the thermistor still inside the heat block?
Peter
Opublikowany : 03/03/2017 9:14 pm
David Wybourn
(@david-wybourn)
Yes, I double checked that. The thermistor hasn't moved.
Opublikowany : 03/03/2017 9:41 pm
theologos.m
(@theologos-m)
Check the cables.
Opublikowany : 13/07/2017 12:44 pm
JeffJordan
(@jeffjordan)
Member Moderator
mixed up the bed and the hotend thermistor at the rambo ?
aaah, just a moment: not every print starts with heating up the hotend ! it depends on how the start script inside the gcode is structured.
is your "set temperature" still 0°C ? or is it something around 200°C and still nothing happens ?
might even be that your hotend heating cartridge is disconnected from the rambo... so that it really remains at room temperature.
____
I really don't understand why this 4 month old thread has been resurrected.
I would imagine the OP has managed to resolve the problem by now.
Peter
@Peter: good point, didn't notice that :mrgreen:
Opublikowany : 13/07/2017 12:58 pm
PJR
 PJR
(@pjr)
Peter
Opublikowany : 14/07/2017 12:19 am
