Hoping for some help with my prints. (Long sorry)
Deadlysquirrel
(@deadlysquirrel)
Hi guys,
I've had my printer for a little while and I'm starting to feel like getting a good finished print is dumb luck.
Here is a list of issues I've tried to tackle:
- bed adhesion
- warping
- stringing
Today I reset everything. Grabbed a new FFF file from here for S3D, redid all the calibration steps and readjusted Live-Z.
I'm going to share some pics of my top and bottom layer calibration cube, a failed small print and a lattice cube I tried to print.
Here are some stats:
AMZ3D PLA 1.75mm
first layer temp 200
second layer temp 195
rest of print temp 190
bed temp 55
default print speed is 45mm/s
first layer height 110%
first layer speed 30%
Extrusion Multiplier 0.98
Extrusion width 0.38
retraction 1mm at 50mm/s
coast 0.20mm
layer height .2
Any input at all would be very very appreciated.
Top Layer
Bottom Layer
Failed Small Print
Curling/Warping
Rough edges 1
Rough edges 2
Respondido : 21/08/2017 12:09 am
AJS
 AJS
(@ajs)
Re: Hoping for some help with my prints. (Long sorry)
A few things I notice:
1) Based on your bottom layer, you do not have your Live-Z set correctly. See the "Life Adjust Z - my way" thread, and read till you get to the V4 version of his code. The first layer is key. Other hints here:
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
The lack of adhesion, curling, and failed small prints are all Live-Z related.
2) Those temperatures seem low for PLA. You might want to bump them both up just a bit. Try 5 degs each. And see if you have any improvement.
3) To issolate machin issues and slicer issues, it is worth printing a few things from the included SD card. If they print fine, and things you slice don't, it is a slicer problem. If they print poorly, then it is a hardware issue.
Respondido : 21/08/2017 12:26 am
Deadlysquirrel
(@deadlysquirrel)
Trying this now. I will post here when its done! I really do appreciate the help!
Respondido : 21/08/2017 12:45 am
Deadlysquirrel
(@deadlysquirrel)
ok so here we have the calibration
the left side of the square is where I think it's properly dialled in
-355 on the Live-Z
Respondido : 21/08/2017 2:40 am
