High Power Mode Print Speed
adrian.s2
(@adrian-s2)
I have just started printing in high power mode due to a suspected glitch on my Mark 2 in silent (low power) mode.
Will this enable me to print faster or does it not make any difference to silent (low power) mode?
I'm using the default slicer settings at the moment.
Does anybody have any experience using faster print settings on the Prusa Mk 2 in high power mode?
I'm using PETG exclusively if this affects the likely acheivable speed.
Thanks in advance.
Veröffentlicht : 20/09/2016 4:58 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: High Power Mode Print Speed
Adrian
Print speed and acceleration go hand-in hand. You can print small models at "high speed" but the acceleration factor will not allow the printer to reach the specified speeds.
Having said that, I have printed (with the Mk1 with V6) 0.2mm large models at 180mm/sec with significantly increased acceleration settings without issue, but I think that is approaching the printer's limits.
My acceleration settings for fast printing:
M201 X1500 Y1500 E900
Peter
EDIT: I always use High Power mode...
Veröffentlicht : 20/09/2016 9:55 pm
adrian.s2
(@adrian-s2)
Thanks for the info.
Not meaning to appear stupid but I'm not confident what that GCode means or where I would use it. 😳
I've only ever tweaked Slicer in the 'Speed for print moves' in the 'Speed' menu in slicer.
Would you be able to advise what the max usable values would be for the Mk 2 using PETG?
Thanks in advance,
Veröffentlicht : 20/09/2016 11:48 pm
PJR
 PJR
(@pjr)
Adrian
Sorry, I can't advise you regarding Slic3r as I have never used it, although I am aware that you insert the acceleration settings in the program which then generates GCode according to those settings.
Peter
Veröffentlicht : 21/09/2016 9:35 am
