Help identify problem with print
I have recently been having problems with layers shifting, or at least that is what I think is going on. It doesn't seem to happen at a reliable z height and sometimes manifests as poor corners. Below are some pictures of the problems I have been having.
You can see in the picture that at the top of the print it starts shifting where it should remain a straight line. Does anyone have any ideas for what I need to adjust to get things printing well again.
Thanks,
Nathan
Re: Help identify problem with print
Hello Nathan!
Well there are numerous things that can make it print like that. See http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html , section 'Print suddenly shifts in X or Y and keeps printing'.
So please check those things - we can take it from there after that, if nothing seems to help.
/Henrik
I have looked through that guide, I will have to check on my belts, they didn't feel too loose last night but I will check again. The shift seems to be gradual and not a sudden shift.
The slow shifting would let me look at the motor pulleys. Check that they are tight on the motor axle.
Carsten
My Prints: https://www.prusaprinters.org/social/15695-carsten/prints
My Employer: https://make-magazin.de
I will take a look at that tonight, didn't get a chance to mess around with it last night. Thanks!
