Help for print x-end-idler!!
SmalLabs.net
(@smallabs-net)
Hi man! I need help for re-print x-end-idler in photo
The problem is that ,my printed x-end idler not lock the bearing(lm8uu)in place sufficiently.
I have print with this setting:
20%infill
and try to--> res 0.2 0.35
I try to change extruder multiplier from 1 to 1.1 .
I try to scale about 1% the model.. (in this case the problem is the holes for bar it's to small.
What can I try 🙁
Postato : 14/06/2017 8:36 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Help for print x-end-idler!!
www.tinkercad.com
Peter
Postato : 14/06/2017 9:51 pm
can you wrap sticky tape (sellotape or similar) round the bearing to increase it's size? and save having to reprint the parts at all?
Postato : 14/06/2017 10:32 pm
SmalLabs.net
(@smallabs-net)
Hi! Tnx for reply,
Peter u mean i should use www.tinkercad.com for edit stl?
Joan yep i have wrap my probe and lm8uu with tesa when i assembled ...
I have solved editing bearing file with new diameter in the scad dir so I just re-render x end idler 😀 Tnx to all!
Postato : 15/06/2017 12:07 pm
PJR
 PJR
(@pjr)
Peter u mean i should use http://www.tinkercad.com for edit stl?
Yes, that's exactly what I did when I needed modified X axis parts. Then printed with PLA and they were very accurate.
Peter
Postato : 15/06/2017 12:18 pm
SmalLabs.net
(@smallabs-net)
I'm try to print with ASA it's like ABS but much stronger and less shrinkage . I'm try to edit with thinkercad I see have not function for get in place perfectly an object in refer to another.
Postato : 15/06/2017 12:38 pm
PJR
 PJR
(@pjr)
No, but with a bit of manual "jiggling" you can get to within 0.05mm which for all intents and purposes is sufficiently accurate.
Peter
Postato : 15/06/2017 12:52 pm
SmalLabs.net
(@smallabs-net)
I use Fusion360 _with function convert mesh -> brep , then I split body and merge again obtain a solid model 😀 With precise tools!
I have try to open extruder body scad ... openscad freeze XD happen the same to you?
Postato : 15/06/2017 1:14 pm
