Heating Block damaged
daniel.m38
(@daniel-m38)
Ok so I had a problem where I had a huge blob of pla melted on to the end of my extruder. When I tried to get it off the wires for the themistor and heating element broke off. Is there a replacement part avaiable, with new cables? Can't find a replacement part on your shop.
Regards
Dani
Respondido : 13/07/2017 7:43 pm
slippyr4
(@slippyr4)
Re: Heating Block damaged
It’s a genuine e3d v6. Replacement parts are available from e3d in the uk, as well as other suppliers in other countries.
Respondido : 13/07/2017 8:45 pm
daniel.m38
(@daniel-m38)
During a lot of reading i checked that i need a new heater cartridge and a new thermistor
Should i take the 12v/30W or 12v/40W
http://e3d-online.com/index.php?route=product/search&search=heater%20cartridge
Which thermistor should i take there are so many
http://e3d-online.com/index.php?route=product/search&search=thermistor
Whats built in my MK2S?
Thanks for supporting a newbie
Respondido : 13/07/2017 9:27 pm
JeffJordan
(@jeffjordan)
Miembro Moderator
unless you use an E3D hotend with PT100 thermistor, the firmware is compiled by default for the following thermistor type (you'll find this inside the Configuration_prusa.h file of the source code):
// 5 is 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (4.7k pullup)
so this one is the right one.
about the heater cartridge:
for some designs e3d doesn't recommend to use the 12V/40W version.... but for our mk2(s) and the minirambo it should be no problem.
as far as I know, originally a 12V/30W cartridge is assembled and the pid values inside the firmware are ment for the 30W heater (but you can do a pid calibration if you take the 40W one).
Respondido : 13/07/2017 9:58 pm
